IAC Twingo Sensor Problems
14 years 7 months before #17501 by manual-mecanica
IAC Twingo sensor problems posted by Manual-Mecanica
Good morning, I have a problem with the acceleration of my twingo
since in rest mode it accelerates and decelerates continuously, they have told me that it is the IAC valve, in any case I would like to know where it is located and how to do maintenance in case it is repairable
14 years 7 months before #17503 by manual-mecanica
Manual-Mecanica Answer on the Re: problems with IAC Twingo sensor
is located in the butterfly box
14 years 6 months before #17514 by manual-mecanica
If but you should be careful the oscillations in relief, they are mainly the fault of the IAC but it may be failing another component, this valve goes in the admission body can take it very carefully and clean it, it would also be good that you would clean the body so that there are no Inpurate in the system.
