Greetings and thanks before hand !!!!
My problem is as follows, I have a Toyota Corolla Model 91 with a 4A-FE engine, which is driving me foam by radiator and I have a strange failure that does not allow me to put the engine ready (because it always has a failure) Change spark plugs, filters and check the intake but no stability, then I preceded the radiator to drain (to rule To make the pruba defionitive, after doing this I realized that I had foam again (this could mean that it is definitely a cycle problem, but the question is because I do not mix water with oil in the radiator, because it does not heat up, because I do not mix the engine of the engine with water (such as changing color, losing vizcity, etc.) Then having so many because I do not have a confirm Help, please take out someone of such uncertainty.
