Gearbox problem
14 years 7 months before #17517 by manual-mecanica
MANUAL -MECHANICA CASH PROBLEM PROBLEM
You see, I recently split the screw of the speed selector axis, the `` crazy '' gear lever was left, I did not get marches, I went to the official Hyundai workshop but sold the entire selector (€ 95), then I decided Marches, but the 5th speed and the reverse cost them, sometimes entered.
Mount in the car and the gear lever metia from 1 to 4th perfectly, too soft with or without clutch (without a clutch) and the 5th the spit, it had to be with the hand on the lever so that it did not leave, the march behind it came when it won most of the time or entered.
I would like to know what it can be, since the 5th is the least, the important thing is back. Thank you all for reading.
14 years 6 months before #17595 by manual-mecanica
Manual-Mecanica response on the Re: change box problem
and
Hello. What screw you name is or inside the box? If this may be a simple distances regulation, but if it is inside you may have caused damage to the box synchronizers.
luck....
14 years 6 months before #17596 by manual-mecanica
Right now it is a little better, the 5th no longer spits it even though the reverse does not enter very well, could it be that by changing 1 of 2 synchronizers, the new one I have to adjust to the box and changes and therefore it does not gender well?
14 years 6 months before #18134 by manual-mecanica
Hello friend, you have to regulate the veillas to better enter the changes or give it more clutch
