Ford Explorer 97 4.0 failure
14 years 6 months before #17564 by manual-mecanica
Ford Explorer 97 4.0 fault published by Manual-Mecanica
I have an Explorer 97 Automatic Motor 4.0 SOHC 4x4, the fault of the truck is that you work three cylinders, already check it and cut the injectors, the 6 injectors work in high, someone can help me with this problem, beforehand thank you.
14 years 6 months before #17646 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Explorer 97 4.0 Failure
First of all, you have to check in a test bank the state of the injectors to rule out that these are the problem, or look for the pulse that is lost.
