problems with Ford that does not start
14 years 6 months before #17567 by manual-mecanica
Problems with Ford that does not start published by Manual-Mecanica
Good morning I wanted to greet and introduce myself to everyone because I am new in this forum. The problem comes to me with a Ford Fusion, although the engine that has mounted 1.4 I is the same as the party of that cylindrada.es of the year 2004.
For a few days I observed how when turning the contact key it took more time than usual to turn on, little: half second or so, and I also observed how the dashboard took it to start, doing strange things, the digital clock was increasingly delayed It appeared until it pressed it, it was as if in each start something was restarted. That's how I was a few days until suddenly does not do absolutely anything when turning the contact key only a very light noise sounds, but nothing more. The lights work, the ventilation, the radio, etc., so I rule out the battery. When turning the key only two lights are lit that I think are the oil and the anti -theft. They have told me that it can be the starter engine.
I have never changed the battery, it has 75000 km, and it is the first time I am damaged. Thanks anticipated
14 years 6 months before #17586 by manual-mecanica
Manual-Mecanica response on the Re: problems with Ford that does not start
hi, friend.
You could leave by reviewing the main fuses and relays may be loose or damaged.
It is the most basic and lopes to review yourself.
luck............
14 years 6 months before #17590 by manual-mecanica
Yes, it was the first thing I did
14 years 6 months before #17592 by manual-mecanica
Change the battery, they are short by sedimentation of the plates
