Kangoo Renault speed sensor
14 years 6 months before #17779 by manual-mecanica
Kangoo Renault speed sensor published by Manual-Mecanica
How, would anyone know where this sensor is located and how do you work, your frequency signal is digital or analog? What values ​​do you have?, In what frequency range do you work? I already downloaded and consulted the Kangoo manual found on the site, but it doesn't talk much about sensors.
Hopefully and someone can provide me with the data, or give me some clue. I give your kind attention.
Greetings.
14 years 3 weeks before #22454 by manual-mecanica
Manual-Mecanica Answer on the Re: Kangoo Renault Speed ​​Sensor
In my Kangoo EK sensor it is located in the box located under the air filter. It is a cable that is unchanged and the sensor goes to pressure. On the page www.clubamigoskangoo.com.ar
Walter theme was treated
