Peuyot Expert radiator electrventillator
14 years 6 months before #17797 by manual-mecanica
Peuyot Expert radiator published by Manual-Mecanica
Symptoms:
Peutot Expert HDI 1900 of 9 seats
1st excess temperature only in very long retentions such as the capital
2nd ellectroventillator of the water radiator does not jump when it reaches the temperature fixed, reaching 100 %
3rd when connecting the air conditioning if the electro-ventilator
cooling the vehicle
4th my question is: what relex in operation the air conditioning?
And in case of being the Relex, in which position of the vehicle would it be?
14 years 6 months before #17805 by manual-mecanica
It is a Peugeot if so you have to take the front mask where the mustaches and behind there a 5 -pin green relay.
14 years 6 months before - 14 years 6 months before #17812 by manual-mecanica
Thank you for responding
effectively, it is a Peuyot
when you say front mask, do you mean the mask where the fan is hosted to fix it to the radiator I think I understand? As I could inform me, this system carries a switchboard and three relay, do you know anything about the route of this circuit and its components? And wanted in the forum but not found anything on this topic.
I will check the relay to see your status and I already commented, thank you again
Last edition: 14 years 6 months before by .
14 years 6 months before #17817 by manual-mecanica
The mask that I tell you, is when you are in front of the vehicle between the two spotlights there is a small mask that is fixed with two DIES bolts, the challenges and triggers and there is like a plastic grid, it reaches the bottom where the wanted one is located where the hood opens. If sir effectively has three relay but only one commands the switchboard, try this one that I tell you, if it is okay it may not work well the switchboard, usually I install this type of vehicle an aim system that is not complicated to do and turn on and turn off only the electrventillator, it is not complicated to do if you do not find a solution you let me know and tell you how to realize it as it is. The BCI and is complicated to repair but I think they do it in Spain
14 years 4 weeks before #22356 by manual-mecanica
Hello friends, they forgive my delay, the vehicle, since the time so hot amazing mind was not heated. Circular the water, the truth is a mystery, but the issue was resolved just by changing the thermostat that is in the butt. The appearance of the deteriorated thermostat was normal, it was completely closed. Thank you very much for everything
