Problems with the Hyunday Accent 98 box
14 years 6 months before #18011 by manual-mecanica
Problems with the Hyunday Accent 98 box published by Manual-Mecanica
Greetings to all. I have problems with the Hyundai Accent 98 box. I repaired it completely six months ago and does not make the changes. Only third when the electrical connection is removed. The scanner indicated short in the Selenoids A and B. The cables were checked and some cuts were found. The cables were fixed but the problem follows. What do they suggest?
14 years 6 months before #18069 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with the Hyunday Accent 98 box
I advise you to change it for a mechanic, save you a lot of money and avoid problems.
