Volksvagen Pole 1.4 Water Pump 1998
14 years 6 months before #18022 by manual-mecanica
Volksvagen Pole 1.4 Water Pump 1998 Published by Manual-Mecanica
where is the happy water pump, porrrfavorr
14 years 6 months before #18045 by manual-mecanica
Manual-Mecanica Response on the Re: Volksvagen Pole 1.4 Water Pump of 1998
When the alternator strap passes alone for two part, I want to desir through the alternator itself and the Sigual, the water pump would be located the distribution system one of the pine nuts where Planing passes would be the water pump. Hopefully I explained me clearly
14 years 6 months before #18075 by manual-mecanica
looking straight at the engine is quoted to the right side, under the alternator and before the crankshaft.
