Nissan Athleon
14 years 6 months before #18087 by manual-mecanica
Nissan Athleon published by Manual-Mecanica
I have a Nissan Athleon and today it has run out of strength does not go from 50 and it does not rise from revolutions. He is thrown out of clean injectors and have taken the limiter what can the breakdown be?
14 years 5 months before #18206 by manual-mecanica
Manual-Mecanica Answer on the Re: Nissan Athleon
Saves the failure? If you get P07 07 it is the injection pump
14 years 5 months before #18209 by manual-mecanica
Hello, you will see that problem you have to go even Nissan concessar, so that they will make you a reprogramming of the Sofword. It is a patch of control unit of the GR Patrol. This modification of the limiter gives you a guarantee because Nissan is assumed, it is a technical circular
or it can also be crankshaft sensors greetings: Blink:
7 years 3 months before #53002 by manual-mecanica
Manual-Mecanica Response on the Nissan Athleon
CE problem ai conct
