Citroen Xsara does not start derived mass?
14 years 6 months before #18121 by manual-mecanica
Citroen Xsara does not start derived mass? Posted by manual-mecanica
Hello, I am new in the forum and I tell you my problem to see if you can help me. It is about that the interior has been wet in front of the driver's feet, it does not start the bomb I have changed the BSI and remains the same (I do not have to reprogram the new The hose is connected, I am going crazy because I have already changed Bsi pump pump fuse heating
. I put the contact before came from stop light and whistled no longer even the light of stop and the oil flashes too.
14 years 6 months before #18126 by manual-mecanica
Manual-Mecanica response on the Re: Citroen Xsara does not start derived mass?
Hello and I had an Xsara 2.0 hdi 90 cv.and for a problem I have had to change the Bsi.Atncion is not worth the BSI of another car !!!!!!! If you have to change (in case the original has no arrangement) you have to change with a virgin (new) and make a telecarg € 500) .Monta the original bsi of the car and takes it to the house. Just only has it unprogrammed ................ I await your answer ... a greeting
14 years 5 months before #18154 by manual-mecanica
Thank you very much for answering, tomorrow to see if they put my computer and hope it is that but I will not tell you a greeting thank you
