Help with an Audi 80 1.9 TDI
14 years 6 months before #18142 by manual-mecanica
Help with an Audi 80 1.9 TDI published by Manual-Mecanica
See if I explain it briefly. My car expels the alternator strap and got into the crankshaft pulley. The point was passed and only one admission taque was broken, cylinder nº3, to which I gave a new taque mount the cams put the distribution to point Jire the motorcycle, 2 times, and all good only a small problem the engine you will ji with the contact and jira and attempts starts without any problem but does not finish starting. Could I not have the GDR valve installed still?
14 years 6 months before #18146 by manual-mecanica
Manual-Mecanica Answer on the Re: Help with an Audi 80 1.9 TDI
Hello, the valve is EGR and you can start without it, you changed the hydraulic pusher but you looked if the valve is not folded, these engines give broblemas of the piñon de craniñal look at it see how it is, I have the vitula canceled and it goes scary, I have the same car as you. A greeting, luck.
14 years 5 months before #18202 by manual-mecanica
Hello, friend to be able to contrast the topic check if that pump has three tornilos and if so loosen them and move it from position forward or backwards, start having if you are not going well ready
