Volkswagen Polo 1.4 Model 2002
14 years 5 months before #18569 by manual-mecanica
Volkswagen Polo 1.4 Model 2002 Published by Manual-Mecanica
I have a Volkswagen Polo that does not start I put the scannner and I do not give me any answer to say that I check if it is connected and DLC and if the swicht is on the Swicht already check it and everything is well connected and ignited the swicht, something else when putting the swicht does not turn on the light of check all the fuses are fine, this car was stopped for many months without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use without any use. I had outdoors I have come to attach that it can be ECU but I have my doubts.
14 years 5 months before #18574 by manual-mecanica
Manual-Mecanica Response on the Re: Volkswagen Polo 1.4 Model 2002
Hello, there is switch that means interruptor. Sometimes vehicles do not let themselves check you have to try more chances and do not check all food fuses or masses, greetings
