Is it possible?
14 years 5 months before #18826 by manual-mecanica
Is it possible? Posted by manual-mecanica
Hello everyone, is it possible to skim the cylinder head for a diesel self -independent?
For more data it is a Renault F8Q engine (1.9D), which was thrown much more oil than necessary producing self -chire.
Self -independent was detected and the engine was peel in about 5 seconds after the acceleration.
Once the oil was eliminated, the engine works in three cylinders except when starting, which for about 10 seconds works well.
Today I have disassembled and consistently cleaned the injectors and remains the same.
I fear that either the cylinder head has been cracked or the Board has been broken, but would it be possible for 5 self -chly segs to cause it?
Thank you so much
14 years 5 months before #18827 by manual-mecanica
Manual-Mecanica response on the Re: Is it possible?
It is very possible, but it has some other noise or detail to me it seems to me a valve seat.
14 years 5 months before #18834 by manual-mecanica
White moistur and the aforementioned, neither gases to the cooling/oil circuit nor anything.
I cannot know if it consumes water no matter how much time torn off, lest we double some connecting rod.
