Radiad passes water to the auxiliary jar mitsubishi colt
14 years 5 months before #18838 by manual-mecanica
Friend the radiator of my mitsubishi colt glx model 95, the water of the radiator to the auxiliary jar is the lid bouches the new, and is being overheating in the city.
When I turn off the car is to boot the water it can be.
Thank you.
14 years 5 months before #18841 by manual-mecanica
Hello, you will see several proceedings;
1 Verify hot if you have the two hoses of the radiator same temperature 90 degrees if not you have problems in thermostat
2 verify at 90 degrees the glue of the fans
3 if the above procedures mentioned are ok can be a cylinder head
14 years 4 months before #18848 by manual-mecanica
If your thermostat is fine, I recommend that you take your radiator to discard possible obstructions to the passage of water if it continues to warm
