Neon spends gasoline
14 years 5 months before #18839 by manual-mecanica
Neon spends gasoline published by Manual-Mecanica
Well Hello here requesting a help that it can be I have a 96 neon and even if it already ties it (spark plugs and filters) spends a lot : Cheer:
14 years 5 months before #18840 by manual-mecanica
Manual-Mecanica Response on the Re: Neon spends Muha Gasolina
Hello. You would take it to the place to be introduced to the check control, to tell you the regulation of progress and make a self -learned car, of course before having observed if you have any fissure in some hose of gasoline Saaludos
14 years 4 months before #18846 by manual-mecanica
You set the fault indicator (Chek Engine) when you put it on and then go out or remain on, since some malandrines take away the witness focus and the car presents failure but you do not realize, I recommend that you scan it, and check the ranges of function mainly of the oxygen sensor and the temperature sensor, since if these are out of range they are out The vehicle comes to smoke
14 years 4 months before #18869 by manual-mecanica
ok thank you very much for the check of Checare that
