Ford Orion 1.6
14 years 5 months before #18856 by manual-mecanica
Ford Orion 1.6 Published by Manual-Mecanica
Hello, I have a problem with an Orion of the year1992 is a 1.6 of gasoline coburer, I tell you I have no spark in the spark plugs, we have changed coil, switchboard, relays, fuses are fine, impulse sensor etc and I can not have spark apparently this everything (good) but something fails, well if you have an idea because I appreciate you, you tell me something. Graaaaacias
14 years 5 months before #18858 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Orion 1.6
Check the platinum, condenser and cover of Delco, the carboncillo
14 years 5 months before #18860 by manual-mecanica
Check if food (+12V) arrives at the coil, if the failure is probably in the fuse box, sometimes the printed circuits of the back of the box are cut, you will have to repair it or put another
14 years 4 months before #18873 by manual-mecanica
Ok, I managed to start it, but there is a problem only work the 2y3 cylinder because the 1y4 melts the coil, someone knows that it is revealed. thank you
14 years 4 months before #19590 by manual-mecanica
Your car has an ignition ignition, this ignition system has to have all the components in good condition, otherwise the ignition coil suffers in excess. The first thing you have to put is the right spark plug that is the AGPR 22 C1 of Motokraft. Do not look for equivalent in the end not well and the electrodes put them at 1 millimeter of separation. Put some good cables, and a coil. You will forget the problem.
