Ford Orion 88
14 years 4 months before #18990 by manual-mecanica
Ford Orion 88 Published by Manual-Mecanica
Good afternoon, I have a Ford Orion 88, I did the engine a month ago, but after riding it, I did not want to turn on ... Many people give different opinions regarding that, that if the point, that the injection, the fuses, the computer ... !!! I really do not know who to believe, but who can help me about it, would appreciate it.
14 years 4 months before #19588 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Orion 88
The problem you have was very abitual in that type of gasoline engines.
What has happened to you is that the hydraulic taes have been loaded and the valves do not close, which you have no compression in the cylinders.
You have to disassemble the hydraulic and careful taques compressing about 3 millimeters to get the valves to close.
I hope you have checked the sparkling sparkling, if you are missing, it changes directly that of the Coin.
