DISRETIBUCION ENGINE VM
14 years 4 months before #19121 by manual-mecanica
Post to point VM Motor Disrtibuction
I got an engine with the pump pump badly mounted, it does not carry brands only two letrs
13 years 2 months before #33399 by manual-mecanica
Manual-Mecanica Response on the Re: Putting Disrtibcion Motor VM
Hi Joalend you were able to solve it I have the same problem
13 years 2 months before #33400 by manual-mecanica
Hi Joalend you managed to solve it I have the same problem
13 years 1 month before #34933 by manual-mecanica
The letters it has are for the motor of 4 and 6 cylinders now I do not remember well what it is what is it easy to do if you put the engine in PMS and take out the gear of the pump you put the contact and turn the pump until the first cylinder injects depending on the position of the pump key you are going to realize what the correct mark is
