- Thanks received: 1
06-19-2025 Hits: 759 Technology
Borja Bueu wrote: If you have a small leak in the Board of the Carter and in another board they have told me.
If I have removed the filling cover and if what is the oil as with lumps and black dry .. it takes a change of oil and filters already! But if I have done it, it is because I change it and the car goes the same and as they told me the option of changing the engine I want to rule out the engine option before making the oil changes ..
You think it could be that a filter is stuck or the oil is very old. Could you upload both consumption and remove power?
If so, it will be the prox that does the sensor and that of discarding because they have told me that everything is well
greeting
