There is refrigerant in the motor carter!
14 years 4 months before #19462 by manual-mecanica
Manual-Mecanica response on the Re: There is refrigerant in the motor carter!
The first ones that you have to control is the oil filter cooler because they are the first ones that are then broken as there is a passage of oil with water is more feasible that they are mixed and after the last one it always behind the water pump there is a plug of the oil gallery that can break but it is difficult
to fix it if the cylinder I hope you have some solution and wait for your answer
14 years 4 months before #19657 by manual-mecanica
Good night to all the people of the forum. Yá is solved the problem of the refrigerant in the motor carter. The problem is in the water pump, being in contact with the distribution that is of chain deteriorated the pump shaft packaging, throwing all the water inside the engine.
I changed the pump, made three or four motor washes with oil and diesel. A few hours of cleaning the entire admission system and voila, its new filter and its good oil already rular.
Special thanks for your time to Ivacoma, Sarcx, Tico2703.
