TEMPERATURE
14 years 4 months before #19496 by manual-mecanica
Manual-Mecanica Response on the Re: Temperature
As they say he checks if it is the butt joint.
Remove the expansion vessel cap and start the engine, then you go to the expansion glass and look at the water if bubbles leave. If bubbles leaves, the combustion chamber pressure to the cooling system passes.
all the best
