VW GOL
14 years 4 months before #19589 by manual-mecanica
VW GOL PUBLISHED BY MANUAL-MECANICA
I need to know how to change the VW goal ignition drum of 91, thank you.
14 years 4 months before #19612 by manual-mecanica
Manual-Mecanica Answer on the Re: VW Gol
You have to take out the steering wheel and the direction column for the dipe but it is not
14 years 4 months before #19650 by manual-mecanica
Good; the idea is to change the ignition suiche; Then you extract the steering wheel (you have to after loosening the steering wheel, without taking out the nut, hitting the axis with the center, at the same time force the steering wheel between three people, everything at the same time), then extract loosening 3 screws the pieces that form the changes of light and
cross In case you have doubts
14 years 4 months before #19677 by manual-mecanica
Well thank you very much, I'm going to try.
