Chevrolet Corsa Motor Isuzu 1.7
14 years 4 months before #19631 by manual-mecanica
Chevrolet Corsa Motor Isuzu 1.7 Published by Manual-Mecanica
It is the engine and you lose oil. By the distribution plate where the oil pump is.
14 years 4 months before #19632 by manual-mecanica
Manual-Mecanica Response on the Re: Chevrolet Corsa Motor Isuzu 1.7
Tip, always between metals some type of joint or sealant (the metal is never perfect and there is always some pore, and the withdrawal changing it.
Another advice, when an engine is opened all precaution is little, always seal between metals and change everything that carries rubber, seals, toricas etc etc, because since it is open you cure yourself into health.
14 years 4 months before #19637 by manual-mecanica
The retain is new. Thank you
14 years 4 months before #19685 by manual-mecanica
Good Roberto. I had a similar case and then it was that the crankshaft axial caps had a lot of lateral slack.
With a detachable or large screwdriver, check that slaughter on the crankshaft pulley to see if it moves a lot in and out.
Have luck ...
