Support: Passat V6 2.8L oil pressure witness
14 years 4 months before #19662 by manual-mecanica
Support: Passat V6 2.8L oil pressure witness published by Manual-Mecanica
Hi:
You can help me I have a Passat 1999 Motor V6 2.8L which turns on the oil pressure witness more was installed a manometro and shows that the pressure is perfect 80 PSI cold and 65 hot psi. The oil pressure sensor is changed above the temperaruta filter is shown well.
Is there another sensor?
If there is another sensor where heads were checked and carter near fire wall and is not?
Can another sensor make the witness caught?
14 years 4 months before #19663 by manual-mecanica
Manual-Mecanica Response on the Re: Support: Passat V6 2.8L oil pressure witness
The failure is giving you the oil level sensor K goes in the carter ... deskonectalo and komprueba ke does not have moisture the konecor ... When deskonectar it I should already death well a season
14 years 4 months before #19664 by manual-mecanica
Check the cable line may be dough somewhere. Later I warn you if there is another sensor.
