Coil warminet
14 years 4 months before #19672 by manual-mecanica
Co-Minete Chabina Cabina Published by Manual-Mecanica
Hello good!!!!
Someone can inform me because I have overheating coil in VW Sedan 1600 on platinos.
Thanks in advance ...
14 years 4 months before #19673 by manual-mecanica
Manual-Mecanica Response on the Re: Coil Cabina Cabern
Hello, when you have a bad adjustment of the platinos (caliber or gap) or the baquelite that contacts the cam is worn that makes it as a consequence of engine heating. If the platinos are chopped or the spent baquelita it is better to change it and give it the correct adjustment. Try to see and tell us how it was.
14 years 4 months before #19678 by manual-mecanica
good morning JGAB
I made the new distributor's lid
14 years 3 months before #19757 by manual-mecanica
On warming of your coil your coil can be of a lot of alternator corner load and change the condenser if it is postoble you put it 2 ..
