DW8 1.9 Partner Failure
14 years 3 months before #20114 by manual-mecanica
DW8 1.9 Partner Failure Published by Manual-Mecanica
:) Hello everyone, I am Diego forgive if I say something that does not devote what happens is that I am new. I wanted to ask you I have a fault in my Peugeot Partner 2004 with Diesel DW8 1.9 engine is that when I connect the water temperature sensor it is green and 2 pins that is in front of the Cuba del Gasoil the engine empies to make a bell and umea, disconnect and go perfect. I already tried to change the sensor and remain the same. Thank you very much
14 years 3 months before #20118 by manual-mecanica
Manual-Mecanica Answer on the Re: DW8 1.9 Partner Failure
Hi Diego. Check the sensor clable, which is sure to be peeled and touching dough.
PS: If you write in mayor you are shouting or pissed off.
Have luck ...
14 years 3 months before #20245 by manual-mecanica
Sorry I did not know about the mayor I did not want to offend anyone with respect to the sensor works with 12 V input and regulates the exit according to the temperature is the voltage that sends to the computer
8 years 7 months before #51710 by manual-mecanica
Manual-Mecanica Answer on the topic DW8 1.9 Partner
Excuse me if I'm wrong, it is the first time I interact on the page although I have been subscribed for many years, I don't know if it's the right place to ask a question. I need from the year the partner 1.9 d came with ECU because I try to buy a
8 years 7 months before #51762 by manual-mecanica
Since 2003 in my country it depends a lot on where you are greetings
