how to remove Nissan Pick Up drum
14 years 2 months before #21054 by manual-mecanica
How to remove Nissan Pick Up drum published by Manual-Mecanica
Hello, I would like to know how to remove the ta, bor from a nissan pick up steaky nose if a key is reKue or just hit the drum for you to get it the reason is that a rosation is heard inside the drum
14 years 2 months before #21079 by manual-mecanica
Manual-Mecanica Answer on the Re: how to remove Nissan Pick Up drum
The true brake drum?, This devoted to leave freely without the handbag tired obio, but if it does not come out that the central bearing does not also affirm the drum as in the Toyotas Tercel, let us know how you go, sometimes they come out hard because the drum is made a rear and caught the worth.
14 years 3 weeks before #22550 by manual-mecanica
Look if it carries two holes with a thread, and if so, two screws and come out.
14 years 3 weeks before #22560 by manual-mecanica
Unn de echo and it soluces it to kitar the drum is easy and simple only the car is needed, previously kitar the tire and ready the drum for death around and ready with a pokito of force leaves the
14 years 3 weeks before #22561 by manual-mecanica
Unn de echo and the solutions to kitar the drum is easy and simple only the car is needed, previously kitar the tire and ready the drum for death around the mirror and ready with a little pokito of strength comes out the one also leaves
anyway thanks for his attention and the suggestions
