Mercury Muntaineer 2002
14 years 2 months before #21140 by manual-mecanica
Mercury Muntaineer 2002 published by Manual-Mecanica
Hello, I can there with my problem, I would be very good as a good lacamioneta, it is a Merciri Muntainerr Awd with 170mil Miles 2002 Ace 4 weeks I bought it and I was walking well inside what fits and only one day for Hotro the transmission the transmission did not respond completely nothing the truck starts without any problem and accelerates. Cemanos never half signals of some fault and in fact the person who mela blessed the transmission oce 10 meces aber if they had a similar problem that can there thanks to me thanks
14 years 2 months before #21178 by manual-mecanica
Manual-Mecanica Answer on the Re: Mercury Muntaineer 2002
Is automatic or mechanics?
14 years 2 months before #21249 by manual-mecanica
It is automatic
14 years 2 months before #21251 by manual-mecanica
Well, the first thing as a recommendation, if the box is automatic and find out if CE can check the ATF level that if the box allows us through the vayonet, ... it is like a first step to know something more concrete about the failure ...
14 years 2 months before #21253 by manual-mecanica
Thanks for the advice but stop that you do not have the ball to check the transmission oil I do not know if there are another way of checking thank you and teagraesco for your you have how much you need to fix the truck thanks
