MONZA 1.8 DISTRIBUTION BELT
14 years 2 months before #21170 by manual-mecanica
MONZA 1.8 DISTRIBUTION BELT PUBLISHED BY MANUAL-MECANICA
Hello friends, I have problems with the distribution of a monza, since the tensioner of the vibrate strap is not, they told me the tension, the water pump occurs, but I am not sure, if someone knows how to give me their advice.
The other is that the vehicle is too heated and is with a new pump and without thermostat, and one of the hoses is always empty, whether the upper or lower or lower
14 years 2 months before #21175 by manual-mecanica
Manual-Mecanica response on the re: distribution strap Monza 1.8
Hello friend Evox first place the tensioner then the strap when it is already mounted loosen the water pump screws not much taught that the pump turns then uses an adjustable or tube key and you are going to turn the pump up and the tensioner carries a guide as a triangle that triangle that triangle of consideration with the one behind him should not pass since that is his tension until that indication that was given to that indication. radiator and treats that time is at its point I hope it will serve my help
14 years 2 months before #21248 by manual-mecanica
Thanks for your council I will take it into account
