Hyundai ACCEN CRDI 1.5 stops only when accelerating
13 years 5 months before #30490 by manual-mecanica
Manual-Mecanica Answer on the subject Re: Hyundai ACCEN CRDI 1.5 stops only when accelerating
Thank you very much to all those who have helped me solve this nightmare .... mine was the sensor, fuel pressure valve ... I change it and ready .... I start and turn off the check Engine ...
12 years 1 month before #41547 by manual-mecanica
Friends again with the same problem, the car stopped in a climb accelerating at about 50 km/Hy, check Engine.
I thought it was a lack of diesel and put 10 liters started and as 5 km the same when the engine stopped.
In addition problems with the starting engine (start) I sent it to repair and it was excellent, new battery, now I changed the diesel filter starts well and for again ... I think it can be the fuel pressure valve again ...
I think it will be best to scan ...: S
12 years 1 month before #41553 by manual-mecanica
Manual-Mecanica Answer on the Hyundai ACCEN CRDI 1.5
Teibol1 What you have badly will be the MAP is in the admission collector and what he does is see you the engine rejimen. or it is in the admission or is with a fine tube.
sucking that tube you have to change the engine noise
if you do nothing is broken. Try to clean the cable tab OA see if it is full of oil because of the vent of the Valancines cover.
You do not eat it with the NTC that is a temperature or air welter, which will also be in the admission tube and is like a lentil.
Tell you that if the admission tubes are broken or perforated, it also fails.
