Help is requested
14 years 2 months before #21423 by manual-mecanica
published by Manual-Mecanica is requested
I am a mechanic apprentice, it happens that we change Cluchk to a 2002 Cavalier, which after changing it, the pedal will be after a certain use, between 300km. We apply a purge with a new liquid and achieve this distance, if I purge it and only the level, it travels half that is about 150 km or 100km, without presenting a problem, I observe that the liquid gets a little dirty, and I think that in there the problem is going, the clochk is rebuilt, since the original is between about 600 dollars or 7500 Mexican pesos
14 years 2 months before #21446 by manual-mecanica
Manual-Mecanica Response on the subject Re: Help is requested
Hello, the Cluchk will be the EMBREAGUE and if every 300km you have to purge and fill in the problem you have in these options 1. Teacher with 2. Slave winder.
14 years 2 months before #21464 by manual-mecanica
Thanks, I'm going to verify these options, I'm in communication
13 years 11 months before #23424 by manual-mecanica
It does not have to see the 300 but the pedal is burst ,,,, if it does not boot liquid .. it would be main brake bomb ... luck change packaging I think the embolo is stuck
