Mercedes solar roof problem 190e
14 years 1 month before #21429 by manual-mecanica
Mercedes solar roof problem published by Manual-Mecanica
Hello, first of all say that I am new here and if I skip any rule of the forum it is not with bad intention, but that I am not accustomed yet.
Well I have a problem with my Mercedes 190e, the other day I turned on the air conditioning while closing the electric solar roof and repeating the ceiling standing. I understand that there is a manual closure somewhere in the car and what I read in some forums is in the trunk but I can't find it.
If someone were as kind to explain how it closes manually it would be very grateful. Greetings and thanks in advance.
14 years 1 month before #21448 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with sunroof Mercedes 190e
Hello partner, according to you, you have to remove the luggage upholstery from the trunk and oh have to be the roof motor that can be closely closed. A greeting.
14 years 1 month before #21455 by manual-mecanica
Manual-Mecanica Response on the problem with Mercedes solar roof 190e
Thank you so much. I did not imagine that to be so hidden hehe greetings and thanks again.
14 years 1 month before #21468 by manual-mecanica
Hello, the electric motor of the ceiling is left to the left, in the trunk, there wears an axis of plastic with a 17 millimeter key. Touring this plastic axis, white, close or open in the case of electricity.
