motor temperature
14 years 2 months before #21461 by manual-mecanica
Manual-Mecanica response on the Re: motor temperature
Greetings to all, I tell you, today (04/29/11) a chemical washing remaulted the entire cooling system, this is with 2 chemical a de -inclicting Table under varied regime and asta now goes well.
Thank you all for your interest and support. Atte, Enrique Tapia,
14 years 1 month before #22020 by manual-mecanica
Consultation: You would tell me what the liquids you put on, because I have a similar problem and I find no solution. Thank you very much.
14 years 1 month before #22131 by manual-mecanica
Greetings to all, if the Wednesday I put them here here
14 years 1 month before #22134 by manual-mecanica
You already solved your problem, the procedure that the friend and greeting all of Ricardo Venzuela
of Venezuela
13 years 10 months before #24314 by manual-mecanica
colleagues I have a similar problem my car is Hyundai Elantra 2000 Something similar Recaliente a lot seems that the hoses are going to explode the plastic tambito of the radiator repaired it were made of aluminum they changed the rock packaging rectified the cylinder head but they gave it to me yesterday and I see the same precion in the won They ignite the thermostat because it was stuck, the car has not been the car any solution to someone who has passed.
