Daihatsu Terios
14 years 1 month before #21805 by manual-mecanica
Terios Daihatsu computer published by Manual-Mecanica
Greetings I have a question, it is reabiating the A/C of my car it turns out that by mistake the contacts of the relay coil the car the car went out then I went on it and nothing happened but when I bought the new relay the negative signal that comes out of the computer does not give then the relay does not energize my question is if it opens burnt the exit of the
computer
14 years 1 month before #21808 by manual-mecanica
Manual-Mecanica Answer on the Re: Terios Daihatsu computer
No friend, that does not come from the computer that was that the ignition button or the DOND card is located a line or button is burned internally as you check where that pane has to take out all that front then with a current caterar verifies how negative it is negative and which is positive and verify the reflex that are before where you collapsed the bridge there is always another internal in the rifle that you take out that you In the suiche I hope my help serves you
14 years 1 month before #21810 by manual-mecanica
Thank you fried for your answer, but you saw that I have this diagram that is from a terios I do not know if like mine but it is very similar (mine is 2003) and it comes out that both with the positive (which is placing the relay coil) and the negative leave the computer. The truth I hope to be in error and that you are right. I put an image of the diagram so you can see it and frame the points that arrive from the computer.
Thank you very much !!
Image: IMG153.imageShack.us/img153/2187/aireu.jpg
14 years 1 month before #21812 by manual-mecanica
Here I leave the electrical manual that I find is from a terios does not indicate year www.mediafire.com/?9i9xn0txb26WQW3
