Turbo Cirrus 2.4 Manual I think I pass the oil
14 years 1 month before #21937 by manual-mecanica
A lot of blue smoke comes out of the escape remove the bijias are dry not so much but not for that smoke
14 years 1 month before #21938 by manual-mecanica
Check the Admission Pre and Post Turbo, to see if it is passing oil, you will have to check the intercoale also the hose that connects from the intercooler with the motor admission duct, part out
there
14 years 1 month before #21939 by manual-mecanica
They will have a turbo diagram I will disarm it tomorrow tanksss
14 years 1 month before #22102 by manual-mecanica
When the turvo of a car is damaged the bushings in the cudaded oil do not comfundo pairsiera that broke or aligned the rings but not the oil and water seals of the turbo cause tremendous Nuve of blue smoke thanks
