Information order
14 years 1 month before #21948 by manual-mecanica
INFORMATION APPLICATION PUBLISHED BY MANUAL-MECANICA
I have to change a distribution strap in a Volkswagen Pointer with Audi 1.6 engine, I need if you can guide me how I have to position the gears and what reference points can I find on the engine for that operation and what collections I must take, thank you very much thank you
14 years 1 month before #21963 by manual-mecanica
Manual-Mecanica Response on the Re: Information Request
Friend the best way is to take out the spark plug number one and turn the crankshaft until the piston is in the upper dead point, then Czech Aver if some mark blocks you with any of the engine if it does not block anything to you, take another return to the followñal and it reaches the same point, if there are still nothing then you have marked you before disassembling the belt some between the mail and the tool and others with respect to the pulleys and the engine will be more easy to put it.
14 years 1 month before #22052 by manual-mecanica
The steps to follow if the piston 1 that is in the upper point removing the spark plug 1 and in the cluch steering wheel on the contra. proceed to remove vanda. proceeds in reverse for assembly. Always change tensioning pulley and band
