Auto problems (Sensors Urgent !!!!!!!!!!
14 years 1 month before #21994 by manual-mecanica
Manual-Mecanica Answer on the Re: Auto Problems (Sensors Urgent !!!!!!!!!
Cumba, usually the trucks spend oil, I have a double cabin Luv Luv 2,3 and spends a lot of cooling refrigerant too, the point is the other syntoms.
In the case of compression pèrdid Increase, in the case of Vàlvulas you must rectify.
If it is the most serious case, that of a semi-support or rings change the engine tends to sound stronger, a rattle of the piston feels even in the cabin, and if oil continues to pass completely the compression of unistòn, low approx to 80 psi.:)
I hope that serves you
14 years 1 month before #22032 by manual-mecanica
Czech the compression as Jgab says, the loss of power plus the instability of the smoke by the exhaust, it can even be a compromised coil, spark plug cable, it is important that you mention the color of the smoke, if at some point the vehicle and that data are stabilized, if there is a great consumption of refrigerant and things like that, I have a lancer 99 and the biggest problem of the mitsubishi is alternative spare parts do not do well, good luck greetings and abrasses
