Problems Dodge Stratus 01 2.0 L. m/t
14 years 1 month before #22016 by manual-mecanica
Problems Dodge Stratus 01 2.0 L. m/t published by Manual-Mecanica
It turns out that I have a Dodge Stratus model 01 Motor 2.0 and manual transmission. The issue is that the injectors are completely open, so much that gasoline is already passed to the carter and the oil is already contaminated by the excess of gasoline that has sneaked into the pistons.
All the sensors have been checked and we fall into the conclusion that the vehicle computer has problems.
Any advice to continue checking? What sensor can be failing causing that kind of fault? I appreciate your help thanks ...
14 years 1 month before #22034 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems Dodge Stratus 01 2.0 L. m/t
Huy is a good problem that, first of all the injectors provided them in a test bench to check that are not the problem that is, check that they are not open? The second the injectors according to their type if they load above or on the side they can have different problems, if they are of those that carry the Czech side that all the fuel seals of the injectors that are mounted in the bottom This happens is passing constant, as for the sensors you indicate there is no sensor or even the failure of all the sensors together that produce a continuous injection so large that it contaminates the oil. If this happens by aviert injectors is the cumpu and now. Fuerte and tell me about the case this type of failure is interesting.
14 years 1 month before #22223 by manual-mecanica
Hello ... thanks for your comments, after checking the Stratus, we will definitely get another computer, we already exhaust all the posivities and we decided on another computer .. Thank you see what happens. Salu2
14 years 1 month before #22270 by manual-mecanica
ok keep me informed luck
