Problema with ECU DE SCAPE 2003
14 years 1 month before #22047 by manual-mecanica
Prooblema with ECU DE SCAPE 2003 published by Manual-Mecanica
Can anyone tell me how I can try an ECU of a 2003 scape to know if that really is the problem ???
14 years 1 month before #22048 by manual-mecanica
Manual-Mecanica Response on the Re: Problema with ECU DE SCAPE 2003
And what kind of problems are you having a friend?
14 years 1 month before #22049 by manual-mecanica
Well first I had an engine failure in which two cylinders did not work. There were pulses in injectors, the bovines if they work. Subsequently, the start relay had no land. Finally, the board that there was a fuse that melted. It is diagnosed that in the box there is a connection with ten cables (stop speed) that arrive directly to the ECU, but they are harmful seemed to touch some with otrs.
