Records at Ralenti Peugeot 406, year 2002, 2.0
14 years 1 month before #22056 by manual-mecanica
Records at Ralenti Peugeot 406, year 2002, 2.0 published by Manual-Mecanica
Friends of MDM, I want to tell you that a couple of months ago I bought a nice Peugeot 406 of 2002, Bencinero 2.0.
I bought it with a problem in idle, that when lighting the vehicle being cold normal part, accelerated over 1200 rpm and goes down according to the temperature that the engine is taking. The detail is that it has abrupt CPM falls coming to stop on some occasions. This detail is mitigating as the engine takes working temperature, but does not disappear at all and when it reaches a traffic light or crossroads when hooking first and stepping on the accelerator, the engine is stopped again, although it does not always happen. Being on roads or highways, it does not present any problem, the vehicle looks good, it does not pull or have rpm falls, it has good acceleration and the fuel consumption is within the ranges indicated by the manufacturer.
I have plans to take it to a mechanical workshop to review and repair it, but first I would like to understand what may be happening to you, to have some idea of ​​the reason for the fault. I have basic knowledge of mechanics and electronic injection, and less than having testing tools; for which I ask for assistance.
I am already grateful
greetings to the friends of mechanics.
14 years 1 month before #22069 by manual-mecanica
Friend, usually when a vehicle presents problems or oscillations in the release, a problem is considered or supposed to Reventi, now this valve is commanded by the car's computer and it does it by means of signals. Also there a system incorporated into the vehicles that is an electronic accelerator, which causes an equal failure but you do not mention if your vehicle if it has it is removed and cleaned.
All air and fuel filters must be in good condition to eat, now, now there is an important detail, you mention problems with the release but do not mention what kind of problems, if they are oscillations or low revolutions or simply a high electrical consumption, try your vehicle in Relay with all the lights on Radio Radio Heating air and everything We can help you.
