Kia Pride 1.3 Gasoline Year 99
14 years 1 month before #22106 by manual-mecanica
Kia Pride 1.3 Gasoline Year 99 Published by Manual-Mecanica
I have an electrical problem. It does not start, it is the ignition, it only throws a spark when starting and then nothing. I have looked fuses, I have replaced that of theco and nothing, crankshaft sensor does not carry, and I have no electric schemes, I would like to know if someone has them. A greeting
14 years 1 month before #22293 by manual-mecanica
Manual-Mecanica Response on the Re: Kia Pride 1.3 Gasoline Year 99
If you do not carry Sigual sensor then it carries it in the distributor,
14 years 8 hours before - 14 years 8 hours before #23194 by manual-mecanica
In the front shock absorber on the driver's side there are some starter fuses and lights if the connectors are spent changing them if the problem persists, see the ignition coil if it continues it can be starting or cables I will try to get you the electrical scheme. I hope it serves something
Latest edition: 14 years 8 hours before by .
14 years 7 hours before #23195 by manual-mecanica
These cars are equal to Mazda323 review. to the. Earth cables. They go to the engine. The engine free. O Normal. How many km has. O It can be a module or rotation sensor
