There is no spark
14 years 1 month before #22142 by manual-mecanica
There is no spark published by Manual-Mecanica
hello everyone!!!
I have a problem with my car is a Breeze 98 2.0 melts I don't want to turn on. Check the flute of gasoline injectors and if there is gasoline. I already check the spark plugs but there is no spark check the harness that feeds the coil (the central cable) and there is no current. already check the relay asd and it works well ..
Any idea what I have to do ??? I'm already desperate and I don't know what else review ... I need your help to solve this problem:(
14 years 1 month before #22154 by manual-mecanica
Manual-Mecanica Answer on the Re: There is no spark
Give me more vehicle data year and liters
14 years 1 month before #22155 by manual-mecanica
ok apology you are right is a Plymouth Breeze Model 98 2.o.
performing a test with a multimeter check the coil and meda the appropriate resistance. Reading there that can be the serns of the crankshaft.
Is there any way to verify the Sigual sensor?
14 years 1 month before #22157 by manual-mecanica
If you can remove it from your location and connect your positive terminal at the end of the positive pole stack and land the sensor by close to a metal pedas to the front of the sensor you can measure the voltage overwhelmed to the other end of the sensor with the multimeter negativi extreme of the multimeter to the ground and the positive to the other terminal of the sensor you can do several times to see several times to see the sensor. I hope and this serves you. Before this you can go to your car with the connected sensor Tabien you can realize whether it serves or not. Armando Leal Lopez
14 years 1 month before #22158 by manual-mecanica
Hello, I present a similar problem, it is likely to be the follow -up sensor, it must be cleaned and verify that the line is not cut, there are sensors that are calibrated between it and the follow -up and another fixed one (my problem I generate a Peugeot) the sensor function is similar, some also carry censors in the camshaft.
