Corsa 2 computer
14 years 1 month before #22182 by manual-mecanica
Manual-Mecanica Answer on the Re: Corsa 2 computer 2
The doubt is created because another mechanic tells me that the computer does not fail.
14 years 1 month before #22185 by manual-mecanica
Make a scanner, if there are problems from ECU, the scanner will give you the
successful
14 years 1 month before #22193 by manual-mecanica
The Corsa computer controls the signal of the injectors with 2 pins, when it fails, 2 injectors should fail, most of the time the failure is in the wiring and not on the computer, the recommended procedure would be to measure the continuity between the pin of the connector to the computers and the connectors of the injectors, to find accessories.
14 years 1 month before #22281 by manual-mecanica
Like any computer you can partially fail depending on the tracks that are lifted or fail.
