Problems with the NEON 95 gasoline indicator
14 years 1 month before #22235 by manual-mecanica
Problems with the 95 Neon Gasoline Indicator published by Manual-Mecanica
: S I have problems with the gasoline indicator when the tank is sometimes empty and vice versa I want to check the sensor but I don't know where someone can help me? Graxias
14 years 1 month before #22260 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with the Neon 95 gasoline indicator
Hello friend, you are located in the gasoline pump and you must take the back seat there, a lid will be removed and you will see the pump
14 years 1 month before #22262 by manual-mecanica
Well, it is normally the potentiometer that it is in the gas tank, you can check it from the sig. Way remove the gasoline pump even side, it is a float without giving the veículo, it opens the swich and lets the float fall with natural will you see that it will not mark anything, after verifying that the float goes up and keep it for a few seconds, if on the board it does not rise the level of petrol Get out of the Eye Potentiometro, this carries the 12 -volt signal and the signal that comes to the board is varied according to the position of the float if nothing comes out to this the problem does not work the potentiometer eye in some veículos is a sign of earth
14 years 1 month before #22276 by manual-mecanica
The neon brings the fuel pump on the side not under the layout, at least those that arrive in Chile, it is on the right side of the vehicle at the height of the traileroat Here in Chile, it is a bit complicated to take out this pump since you have to fold while goods towards Arriva Porke Atoras the float bolla and when you put it bleeding if you do not do it, the car will not leave for more than you try it has already happened to me. This bomb is lying down and not vertical to the problem luck.
