Toyota Hilux light indicator of gasoline filter
14 years 1 month before #22249 by manual-mecanica
The light filter indicator of the Toyota Filter has been turned on and does not go out. Disconnect the electrical system and wait a few moments and nothing ..., change the filter and continue on! Let's see if someone throws me a fact of solving that! thank you!
14 years 1 month before #22254 by manual-mecanica
Hello friend verifies that the cable is not shortly at some side because it is making the earth verifies the branch and you will see that your fault will solve
14 years 1 month before #22259 by manual-mecanica
Greetings what a model and year is the Hilux
14 years 3 weeks before #22399 by manual-mecanica
Check the cable but do not make land anywhere, thanks for the advice, don't I know if you have any system that is blocked the indicator? The model is 2008.
