COLD FORD EXPLORER PROBLEM 1999
14 years 1 month before - 14 years 1 month before #22250 by manual-mecanica
Cold Ford Explorer 1999 Problems published by Manual-Mecanica
During the vehicle's departure, Readi goes down getting the engine, I must on occasion keep the pedal to increase rpm and then several minutes rpm is normalized in 700 app.
What can be failing and what spare is it necessary to take into account to solve the problem?
Please your comments.
Latest edition: 14 years 1 month before by .
14 years 1 month before #22252 by manual-mecanica
Manual-Mecanica Response on the Re: Problems Party in Frio Ford Explorer 1999
Hello, I recommend that you make a computational check first because you can have an electronic problem and the other is that if your engine in the first moistur idle
14 years 1 month before #22255 by manual-mecanica
My friend normally when that happens is a problem with the IAC valbule, whether it is dirty or plane no longer ages its functions, because the iac valbule is in charge of what your engine is stable in idle or so that you understand me better than it does not turn off when the engine is not accelerating
14 years 1 month before #22274 by manual-mecanica
It is pposible that you have problems with the motor temperature sensor, but before changing that sensor that affects the cold game directly, we have to save if during the day the car starts correctly and if the air and fuel admission system is clean, the other as well as the partner says is the correct state of spark plugs.
