Velocimeter or dashboard lights does not work
14 years 4 weeks before #22341 by manual-mecanica
Velocimeter or dashboard lights published by Manual-Mecanica
Good afternoon
I have a Plymouth Breeze Model 1998 Motor 2.0. This car is getting the green gray hair a large number of failures but little by little they were fixing. The only fault that persists is that the velocimetter does not work
on the dummy lights or the dimmer tanpoco work the rear lights do not work (the curious scheme the stops, the light of reverse and the preventive ones if they work) the nicon not so little works.
I already check all the fuses and they are fine. apparent Nente has an electrical problem. x that you already check the terminals of each device and do not reach current and check everything and do not know what to do.
Some suggestion to help me get out of this problem or one diagram of the Electric System of Post Carro, I would really appreciate your help !!!!: Woohoo:
14 years 4 weeks before #22344 by manual-mecanica
Manual-Mecanica response on the Re: Velocimeter or board lights does not work
Good
I do not know that vehicle or the brand sounds to me what I can contribute to you is that I once had one side of the lights I do not turn on the fuses lights etc. to check the fuses I made it when I check it with a tester was melted.
Check that you have no more fuses or relays in the engine.
It is what occurs to me.
luck
14 years 4 weeks before #22345 by manual-mecanica
Check the lands, sometimes it is isolated that they are isolated and does not circulate current to the load ...
and ovbly check the circuit from the control ... in one of those ta there is only one connector or a loose pin ...
luck !!
14 years 4 weeks before #22354 by manual-mecanica
Ivan I had a pair problem and it was because of the alarm, when the horn was activated, the dashboard and positions even patent, but normal from the command no, I had to review the installation of the complete alarme to find the cable that abian punctured and return it to normal and the problem was resolved, it is informative kisas.
