Water loss of the heating of l Scenic 1.6
14 years 4 weeks before #22343 by manual-mecanica
Water loss of the heating of L Scenic 1.6 published by Manual-Mecanica
I have water loss problems, on the driver's side. I see that the reservoir level drops and the driver's side is wet. It is a Scenic 1.6 of 16 Valves model year 2000.
14 years 4 weeks before #22352 by manual-mecanica
Manual-Mecanica response on the Re: Water Loss of the heating of L Scenic 1.6
Hello, it loses water for the heating radiator and you have to take out the entire room of the habitaculus (dashboard) to be able to remove the heating furniture to change the radiator.
14 years 4 weeks before #22355 by manual-mecanica
This is true, it says Z6668B or you can make a bridge between the hoses to prevent this from happening that you run out of heating
