Diesel Toyota filter light
14 years 3 weeks before #22396 by manual-mecanica
Diesel Toyota Filter Light published by Manual-Mecanica
Someone knows the procedure to erase the warning light of the toyotas when the Diessel filter trap is filled with water after emptying it
14 years 3 weeks before #22402 by manual-mecanica
Manual-Mecanica Response on the Re: Light Diesel Toyota Filter
There is no system if the filter cables are disconnected and it does not turn off must be that it has a short cut in the wiring the signal is direct to the board of the board
14 years 3 weeks before #22410 by manual-mecanica
I thought that but it has already happened to me with several 2008 or newer toyotas or more we have all reviewed the sensor and they are fine
